vcFindFlowStepStatement
Find flow step statement.
LoopingSearchvcExpressionPropertyRGets a property for looping search. When evaluates to True,
the flow step search can loop from end of the sequence to the start and from the start of the sequence to the end.
ProcessToFindvcProcessGroupRWGets or sets the process group to search for.
ReturnStepOffsetvcExpressionPropertyRGets a property for step offset. The
evaluated value determines an offset in number of flow steps forward or backward applied to the result.
SearchDirectionvcSearchDirectionRWGets or sets the value for search direction in the flow sequence.
SearchModevcSearchModeRWGets or sets the value for how the new flow step info is defined.
SkipOptionalStepsvcExpressionPropertyRGets a property for skipping optional steps.
When evaluates to True, an optional flow step can never be returned. The search and offset logic will skip over all optional steps and may fail if a non-optional flow step was not found.
SourceFlowInfoVariableNameStringRWGets or sets the name of the Process variable where to get flow step info used as reference point.
TargetFlowInfoVariableNameStringRWGets or sets the name of the Process variable where to store the result.
